Apparently the codeblock macro has been replaced by code snippets.
Here's my question: you could configure codeblocks to be collapsable. Thus it was possible to hide a good chunk of code when the page opens and the user was able to expand the code that she was actually interested in.
For code snippets I cannot find an equivalent. Has this feature been removed?
If so, it must be put back, lest I will not be able to convert any of my pages to make use of the new editor.
In fact, this possibility is gone. There are some more restrictions with the new code snippet...
Found this feature request:
Feel free to vote for this issue
Regards, Dominic
Hi Dominic_Lagger,
thank you for the hint! I've cast my vote. An I dearly hope to see some advancement, as I just cannot update to the editor with all of these restrictions :-(
Regards Robert
I'm using the Expand macro and inside I add a code block
Hi, Dominic_Lagger,
collapsing the code snippet is the main function of the macro. The reason is obvious to anyone who needs to use such a macro. Why is such a bug as incorrectly removing a key property referred to as an enhancement. Should we expect other similar improvements ?
Regards
Help us plant more trees
