I have created a simple Multi-select dropdown on a form and would like to have different background colours for the lozenge options when shown in TableView, e.g. in the example below, I want the 'Go Live' option to have a green background (with a white text). I can specify a CSS Rule that if 'multiSelect.label:Go Live' then apply 'background:green', but that colours everything in the cell, including the cell background an all the lozenges in the cell.
I tried many different things, for example using a separate form to capture February+Testing and February+Go Live as separate entries and use queryAndRender virtual function to merge them into a single cell, but that doesn't carry over any CSS and just shows a plain list (list option).
Any suggestion would be much appreciated.
Peter
Sorry, this is not currently possible with a built-in ConfiForms functionality
Alex
