The version field seems to not work with direct inline edits (e.g. from CardView) at all. If I use edit controls rendered as inline, the first save gets rejected with an error, but a second click on save overwrites the new version. Can you confirm this behavior and is it intended?
That is somewhat by design
If you want to have a full versionable edit then consider switching away from inline edits
Alex
Hi, thanks for getting back to me. So I guess that means it is not intended behavior but hard to fix due to the overall design? So if it is not going to be fixed anytime soon, I think it should be mentioned in the documentation that the versioning only works for non-inline edits, what do you think?
We can mention that in documentation, if that helps.
But indeed, the individual field value edits go around the version check (as this is only checked when the whole record is edited - either in inline or using the dialog mode (for partial or complete form))
Alex
Thanks for the clarification. Yes documenting it would be good, I think. I think this is a really important feature as it enables a lot of use cases (it enables a lot more flexibility and increased process speed in request - approval scenarios), so it would be very nice if fixing this for inline edits makes it into the agenda of the developers though.
Best
Jonathan
This learning path offers short, self-paced courses to help software teams systematically manage components and services. Compass provides a unified interface for tracking distributed software architecture and team collaboration.
Learn more!
