×If you only want that field to be editable, you need to either set all the fields to read-only in the field configuration or use a plug in to set the behavior while on a specific screen.
If you added a custom field and it is not editable in line, make sure you add it the Edit screen. The view screen is what you normally see, but if you want to edit in line, the field needs to be on the Edit screen also. These are in the screen scheme.
Inline edit is a global setting, on or off (for all fields)
Hi @Nic Brough -Adaptavist- ,
We have disabled Inline edit globally,
But want to enable for particular custom field ,is that possible ?
Thank you,
Varun
See the answer you commented on
Is that possible to enable for particular field ?
I dont want to enable globally.
Again, see the answer given already.
