Hello all,
I started exploring Confiform today and ran into some desired functions that I have not been able to resolve myself, so I'm going to turn to the community for tips.
What I have:
What I want:
I would like to have the B field in the table change color if does not contain the same selected entries from the checkbox as in field A.
Example:
A B
1 1
3 3
4 4
= no color change needed
A B
1 1
2
4 4
= B field needs to change color
I have tried the Confiforms Rules for Fields (CSS) macro for field B where I configured it to -
!A:[entry._func.asEntryRef(entry.B)]
But this only works if B field is completely empty and the other is not. It also changes the color if B not empty but A is, which is an undesired side effect.
Is there a way to get it to function the way I want?
Hey @Mike vD ,
Digging this one out of the grave, but for future reference (and if you still have questions related to ConfiForms or other Marketplace apps), I'd suggest reaching out to vendors directly.
Each app should have a Support tab in its Marketplace listing (example for ConfiForms) so you can discuss everything with the vendor's support team. They are all usually quite responsive when it comes to questions about their apps.
If you do have any questions about native functionalities, feel free to write them down ✍️
Tobi
