I have a form, let's call it 'Report'. As part of this report, there may be 0...n Findings.
I would like to be able to create a Finding from a button in Report, and have Finding be a child of Report.
Also, any Findings should be displayed in a table in Report.
I had tried 2 Form Definitions in my page, and can get the Finding to pop-up, but it won't display as per Registration Controls, nor will it save as a child to the Parent (saves but isn't in navigator).
I've been informed that Confiforms does not support subforms (see my only other post). The attached image shows a simplified example of what I'm trying to achieve.
Any suggestions or examples for how I can achieve this goal?
Take a look at this field type https://wiki.vertuna.com/display/CONFIFORMS/ConfiForms+Smart+Multi-row+-+what+it+offers+and+how+to+use+it
probably it is what you need
Alex
