Confiforms: Prevent deletion of dependent entries
Mandy Butschke-Lange August 16, 2024
I have a form “form1” with a text field “option”. I use the values entered here in a “form2” as a smart dropdown.
Is there a way to prevent an entry from being deleted in “form1” if this entry has already been used in “form2”?
Alex Medved _ConfiForms_
August 16, 2024
Hi @Mandy Butschke-Lange
You can add a "Validation on Delete" rule - https://wiki.vertuna.com/display/CONFIFORMS/ConfiForms+Field+Definition+Rules#ConfiFormsFieldDefinitionRules-Validateondelete
And utilize the queryCount function to check the number of records matching in another form (and if that's larger than 0 then the rule will trigger and abort the delete operation)
https://wiki.vertuna.com/display/CONFIFORMS/Virtual+functions
Alex
Mandy Butschke-Lange August 19, 2024
Hi @Alex Medved _ConfiForms_
thanks for your help. This works perfectly for field type "Smart Dropdown". But when I change the field type to "Smart Multi-Select" unfortunatly it doesn't work anymore. It seems like the "queryCount"-function doesn't work for "Smart Multi Select"? Do you have an advise how I can get this working?
Here is my code for the "Smart Dropdown" (field "Dropdown" in "form1") where everything works fine. The “Dropdown” field in “form1” should actually be a "Smart Multi Select".
<ac:structured-macro ac:name="confiform" ac:schema-version="1" ac:macro-id="404f0cac-3c3b-484e-a56c-a51aaebd2947"><ac:parameter ac:name="hideAdminUI">true</ac:parameter><ac:parameter ac:name="formName">form1</ac:parameter><ac:parameter ac:name="autoDelete">true</ac:parameter><ac:parameter ac:name="allowReads">true</ac:parameter><ac:rich-text-body>
<p class="auto-cursor-target"><br /></p><ac:structured-macro ac:name="confiform-entry-register" ac:schema-version="1" ac:macro-id="ab168557-cf1e-4649-bba6-dc52f806bb11"><ac:parameter ac:name="formName">form1</ac:parameter><ac:parameter ac:name="registrationButtonLabel">Add new entry</ac:parameter><ac:rich-text-body>
<p><br /></p></ac:rich-text-body></ac:structured-macro>
<h3><ac:structured-macro ac:name="confiform-field-definition" ac:schema-version="1" ac:macro-id="daa13408-13e9-4cfe-b9fe-077d8ee31099"><ac:parameter ac:name="fieldName">Dropdown</ac:parameter><ac:parameter ac:name="fieldLabel">Dropdown</ac:parameter><ac:parameter ac:name="values">[3682352296|DropdownValues|DropdownValue|true||]</ac:parameter><ac:parameter ac:name="type">smartselect</ac:parameter></ac:structured-macro></h3>
<h3><ac:structured-macro ac:name="confiform-field-definition" ac:schema-version="1" ac:macro-id="27177bfb-af43-4209-8a0c-9ad995c6fb6a"><ac:parameter ac:name="fieldName">Name</ac:parameter><ac:parameter ac:name="fieldLabel">Name</ac:parameter><ac:parameter ac:name="type">text</ac:parameter></ac:structured-macro></h3>
<p><ac:structured-macro ac:name="confiform-field-definition" ac:schema-version="1" ac:macro-id="889ea4d6-8da7-486f-b478-91951b994469"><ac:parameter ac:name="fieldName">DropdownID</ac:parameter><ac:parameter ac:name="fieldLabel">Dropdown ID</ac:parameter><ac:parameter ac:name="type">hidden</ac:parameter></ac:structured-macro></p><ac:structured-macro ac:name="confiform-ifttt" ac:schema-version="1" ac:macro-id="a11307f5-36bc-4008-834b-89b01a0cdcbc"><ac:parameter ac:name="extras3">true</ac:parameter><ac:parameter ac:name="action">Create ConfiForms Entry</ac:parameter><ac:parameter ac:name="event">onModified</ac:parameter><ac:parameter ac:name="title">entryId=[entry.id]&amp;DropdownID=[entry.Dropdown.id]</ac:parameter><ac:rich-text-body>
<p><br /></p></ac:rich-text-body></ac:structured-macro><ac:structured-macro ac:name="confiform-ifttt" ac:schema-version="1" ac:macro-id="80bbcd8b-3b99-48e4-bd04-6e34539c4066"><ac:parameter ac:name="extras3">true</ac:parameter><ac:parameter ac:name="action">Create ConfiForms Entry</ac:parameter><ac:parameter ac:name="event">onCreated</ac:parameter><ac:parameter ac:name="title">entryId=[entry.id]&amp;DropdownID=[entry.Dropdown.id]</ac:parameter><ac:rich-text-body>
<p><br /></p></ac:rich-text-body></ac:structured-macro></ac:rich-text-body></ac:structured-macro><ac:structured-macro ac:name="confiform-table" ac:schema-version="1" ac:macro-id="7e85e8a9-6ddb-4ab0-bce9-c6693c05a507"><ac:parameter ac:name="pager">NO LIMIT</ac:parameter><ac:parameter ac:name="formName">form1</ac:parameter><ac:rich-text-body>
<h1 class="auto-cursor-target"><ac:structured-macro ac:name="confiform-field" ac:schema-version="1" ac:macro-id="b9678db2-82a8-4b01-ada2-8b677c46fb20"><ac:parameter ac:name="fieldName">id</ac:parameter></ac:structured-macro></h1>
<p class="auto-cursor-target"><ac:structured-macro ac:name="confiform-field" ac:schema-version="1" ac:macro-id="eb98c894-e239-41ae-a3dc-da768d699378"><ac:parameter ac:name="fieldName">Dropdown</ac:parameter></ac:structured-macro></p>
<p class="auto-cursor-target"><ac:structured-macro ac:name="confiform-field" ac:schema-version="1" ac:macro-id="7f48af44-0187-4581-910b-240414b2cefb"><ac:parameter ac:name="fieldName">Name</ac:parameter></ac:structured-macro></p>
<p class="auto-cursor-target"><ac:structured-macro ac:name="confiform-field" ac:schema-version="1" ac:macro-id="61367dbf-a87e-4b7c-b9e7-75dda2ac9857"><ac:parameter ac:name="fieldName">DropdownID</ac:parameter></ac:structured-macro></p><ac:structured-macro ac:name="confiform-entry-edit" ac:schema-version="1" ac:macro-id="42acb172-e9a1-4126-a798-96049efd90af"><ac:rich-text-body>
<p><br /></p>
<p><br /></p>
<p>Dropdown Values</p><ac:structured-macro ac:name="confiform" ac:schema-version="1" ac:macro-id="d00a03ea-57aa-419c-9a55-63f896f78ab6"><ac:parameter ac:name="hideAdminUI">true</ac:parameter><ac:parameter ac:name="formName">DropdownValues</ac:parameter><ac:parameter ac:name="autoDelete">true</ac:parameter><ac:parameter ac:name="allowReads">true</ac:parameter><ac:rich-text-body>
<p class="auto-cursor-target"><br /></p><ac:structured-macro ac:name="confiform-entry-register" ac:schema-version="1" ac:macro-id="072e6c7f-20cf-4ff9-9c30-9eaaa421275c"><ac:parameter ac:name="css">background-color:#442EE0</ac:parameter><ac:parameter ac:name="formName">DropdownValues</ac:parameter><ac:parameter ac:name="registrationButtonLabel">Add new item</ac:parameter><ac:rich-text-body>
<h3><ac:structured-macro ac:name="confiform-field-definition" ac:schema-version="1" ac:macro-id="e3623cb6-e8be-4103-aa95-e7a93afa8a14"><ac:parameter ac:name="fieldName">DropdownValue</ac:parameter><ac:parameter ac:name="fieldLabel">DropdownValue</ac:parameter><ac:parameter ac:name="values">false[]</ac:parameter><ac:parameter ac:name="fieldDescription">Please enter the name of the CPM process you want to add</ac:parameter><ac:parameter ac:name="type">text</ac:parameter><ac:parameter ac:name="required">true</ac:parameter></ac:structured-macro></h3>
<p><ac:structured-macro ac:name="confiform-field-definition-rules" ac:schema-version="1" ac:macro-id="b9e061b3-6ff8-47d0-8f39-aa1ed0dbe582"><ac:parameter ac:name="condition">id.queryCount(form1:@self;DropdownID:[entry.id]):&gt;0</ac:parameter><ac:parameter ac:name="fieldName">Dropdown value is in use</ac:parameter><ac:parameter ac:name="action">Validate on delete</ac:parameter></ac:structured-macro></p>
<p><br /></p></ac:rich-text-body></ac:structured-macro><ac:structured-macro ac:name="confiform-table" ac:schema-version="1" ac:macro-id="7354f908-361f-4330-a497-ec04957d67bd"><ac:parameter ac:name="pager">NO LIMIT</ac:parameter><ac:parameter ac:name="formName">DropdownValues</ac:parameter><ac:parameter ac:name="debugMode">true</ac:parameter><ac:rich-text-body>
<p class="auto-cursor-target"><ac:structured-macro ac:name="confiform-field" ac:schema-version="1" ac:macro-id="8d2032fe-57e5-4e9b-8d4c-44e7e89aac1f"><ac:parameter ac:name="fieldName">id</ac:parameter></ac:structured-macro></p>
<p class="auto-cursor-target"><ac:structured-macro ac:name="confiform-field" ac:schema-version="1" ac:macro-id="5625a1b4-94bc-4242-afc4-b9a91c231896"><ac:parameter ac:name="fieldName">DropdownValue</ac:parameter></ac:structured-macro></p>
<p class="auto-cursor-target"><ac:structured-macro ac:name="confiform-field" ac:schema-version="1" ac:macro-id="02670e15-b156-478e-92ec-56406d0d53a0"><ac:parameter ac:name="overrideLabel">Count used dropdown values</ac:parameter><ac:parameter ac:name="fieldName">id.queryCount(form1:@self;DropdownID:[entry.id])</ac:parameter></ac:structured-macro></p><ac:structured-macro ac:name="confiform-entry-edit" ac:schema-version="1" ac:macro-id="a1147782-624c-43a7-b5c4-045e7fef0806"><ac:rich-text-body>
<p><br /></p>
 Mandy
August 19, 2024
Same as with single choice fields
See the example below (you dont need a temporary field as in your configuration)
<ac:structured-macro ac:macro-id="404f0cac-3c3b-484e-a56c-a51aaebd2947" ac:name="confiform" ac:schema-version="1">
<ac:rich-text-body>
<br/>
</p>
<ac:structured-macro ac:macro-id="ab168557-cf1e-4649-bba6-dc52f806bb11" ac:name="confiform-entry-register" ac:schema-version="1">
<ac:rich-text-body>
<p>
<br/>
</p>
<h3>
<ac:structured-macro ac:macro-id="c5819915-d492-4d48-98fb-031cccc2b13f" ac:name="confiform-field-definition" ac:schema-version="1">
<ac:parameter ac:name="type">smartmultiselect</ac:parameter>
</h3>
<h3>
<ac:structured-macro ac:macro-id="27177bfb-af43-4209-8a0c-9ad995c6fb6a" ac:name="confiform-field-definition" ac:schema-version="1">
</h3>
<ac:structured-macro ac:macro-id="7e85e8a9-6ddb-4ab0-bce9-c6693c05a507" ac:name="confiform-table" ac:schema-version="1">
<ac:rich-text-body>
<ac:structured-macro ac:macro-id="b9678db2-82a8-4b01-ada2-8b677c46fb20" ac:name="confiform-field" ac:schema-version="1">
</h1>
<ac:structured-macro ac:macro-id="eb98c894-e239-41ae-a3dc-da768d699378" ac:name="confiform-field" ac:schema-version="1">
</p>
<ac:structured-macro ac:macro-id="7f48af44-0187-4581-910b-240414b2cefb" ac:name="confiform-field" ac:schema-version="1">
</p>
<ac:structured-macro ac:macro-id="61367dbf-a87e-4b7c-b9e7-75dda2ac9857" ac:name="confiform-field" ac:schema-version="1">
</p>
<ac:structured-macro ac:macro-id="42acb172-e9a1-4126-a798-96049efd90af" ac:name="confiform-entry-edit" ac:schema-version="1">
<ac:rich-text-body>
<p>
<br/>
</p>
<p>
<br/>
</p>
<p>
<br/>
</p>
<ac:structured-macro ac:macro-id="d00a03ea-57aa-419c-9a55-63f896f78ab6" ac:name="confiform" ac:schema-version="1">
<ac:rich-text-body>
<br/>
</p>
<ac:structured-macro ac:macro-id="072e6c7f-20cf-4ff9-9c30-9eaaa421275c" ac:name="confiform-entry-register" ac:schema-version="1">
<ac:rich-text-body>
<p>
<br/>
</p>
<h3>
<ac:structured-macro ac:macro-id="e3623cb6-e8be-4103-aa95-e7a93afa8a14" ac:name="confiform-field-definition" ac:schema-version="1">
</h3>
<p>
<ac:structured-macro ac:macro-id="1125ac13-3776-4aea-bd60-2c77cebaa511" ac:name="confiform-field-definition-rules" ac:schema-version="1">
<ac:parameter ac:name="condition">id.queryCount(form1:@self;Dropdown:[entry.id]):&gt;0</ac:parameter>
</p>
<p>
<br/>
</p>
<ac:structured-macro ac:macro-id="7354f908-361f-4330-a497-ec04957d67bd" ac:name="confiform-table" ac:schema-version="1">
<ac:rich-text-body>
<br/>
</p>
<ac:structured-macro ac:macro-id="8d2032fe-57e5-4e9b-8d4c-44e7e89aac1f" ac:name="confiform-field" ac:schema-version="1">
</p>
<ac:structured-macro ac:macro-id="5625a1b4-94bc-4242-afc4-b9a91c231896" ac:name="confiform-field" ac:schema-version="1">
</p>
<ac:structured-macro ac:macro-id="682163f8-216e-4fb1-a45d-7888471d8882" ac:name="confiform-field" ac:schema-version="1">
<ac:parameter ac:name="fieldName">id.queryCount(form1:@self;Dropdown:[entry.id])</ac:parameter>
</p>
<ac:structured-macro ac:macro-id="a1147782-624c-43a7-b5c4-045e7fef0806" ac:name="confiform-entry-edit" ac:schema-version="1">
<ac:rich-text-body>
<p>
<br/>
</p>
<p>
<br/>
</p>
Thank you very much for your quick reply. I have also just found my error and it now works as in your example.
