I have a problem with Edit Controls in TableMerger.
I don't use dynamic sources. Inside TableMeger I have several TableViews.
I also use Edit Controls inside TableMerger because I would like to give the user the ability to copy records.
Almost everything works fine, except one thing - the title of the Registration Form, regardless of which Form I want to copy is always the same - it's the title of the Forms from the last TableView inside TableMerger.
How to fix it?
Example below.
The interior and layout of the Registration Form are correct, but the title itself is always the same.
Problem solved - I added Rules "Set form title" to each form.
Nevertheless, it may be worth considering solving above issue without additional Rules?
Register now
