Confiforms: formatNumberWithLocale and smart multi-row
Bartosz Drożdżal
Hi @Alex Medved _ConfiForms_
I came across an unusual case.
I want to pass values ​​from a multi-row field to Jira descritpion field.
One of the values ​​is the currency.
I use the iterateAndPrint, formatNumberWithLocale(en) and renderAsHtml functions. Unfortunately, I noticed that sometimes JSON cuts off parts of the amount where the string "000" appears.
My description snippet in JSON looks like this:
"Data \r\n |CIS|Currency|Segment| \r\n [entry.multirowfield.iterateAndPrint(|[entry.CISfield.escapeJSON]|[entry.currencyfiled.formatNumberWithLocale(en).escapeJSON]|[entry.segmentfield .label.escapeJSON]|. \r\n).renderAsHtml \r\n]|. \r\n "
My input:
My output:
What am I doing wrong?
August 5, 2024
Hi @Bartosz Drożdżal
Do you know when this "sometimes" occurs?
When I test this I see the number formatted correctly
Create a view over your form to see how the data is rendered for each row in ConfiForms
May be this way you will get an idea about the "difference" and that will help you to understand when/why this happens
Alex
Bartosz Drożdżal
When it comes to confluence, everything looks correct.
Data is not displayed correctly in the Jira task.
The output screenshot comes from Jira.
August 5, 2024
Then it is something to look into in Jira... I afraid
SERVER
