×Hello,
I would like to find out if a really old version of Confluence (v3.2.1) is compatible with an Oracle DB (v 19c).
We currently have an Oracle DB version 10g.
We are forced to upgrade the DB to 19c, and the upgrade of Confluence is not possible from our side.
Is there a way to find out the compatibility?
Thank you in advance.
Br,
Dan
Hi @Christian Danny , welcome to the Atlassian Community!
For new versions it would be as easy as checking the supported platforms: https://confluence.atlassian.com/doc/supported-platforms-207488198.html
For older version you need to dig through old documentation, it looks like v3.2.1 is there, and .pdf show some results for search of 'oracle' so the info is probably there, check: https://confluence.atlassian.com/alldoc/confluence-documentation-directory-12877996.html
(Btw. you are lucky, recently I was checking something for Jira 3.x and it was not available ;/ )
