Hi, i'm new to automation in Confluence. I have recently been trying to trigger the creation of a Jira Issue using Automation in confluence, however it just continues to say loading, when i try to select issue type.
Never get any values to select from at all
Does anyone have any guidance on what may be causing this?
Hi @Craig_Harley , thanks for your question.
Have you tried with different projects, just to see if something is retrieved? Have you tried with different browsers?
Another good place to check is https://confluence.status.atlassian.com/ . I can see there was some issue with automation in Confluence earlier this week so maybe you were just trying at a time when something else was going on.
Let us know if the issue persists or if you have other questions.
Cheers
Thanks for the response Valerie,
had tried different projects and tried a few different times on different days.
however yesterday, it just started working again
Hi @Craig_Harley , thanks for your reply. I'm sorry for the problem but I am happy it is resolved now... even if it's not clear how. Let's hope it stays this way.
