I alread you the following command to create backup from pages:
/opt/atlassian-cli/acli confluence --action runFromPageList --space MBSU --id 1214709818 --continue --descendents --regex "A.\d.\d.\d.*" --common "--action copyPage --id @pageId@ --parent \"@title@\" --newTitle \"@title@-anf\""
This is quite smart, because the backup page has a similar name as the original page.
For runFromPageList it is quite necessary to use a good regex to find the right pages.
But sometimes runFromCsv is much easier.
So I used runFromCsv with modifyPage action. And inside the structure information I try to use @title@. But this did not work.
Is there a way to use @title@ in the structure data information?
Here is my test command using @title@:
acli confluence --action runFromCsv --file ./test.csv --propertyFile ./cli.properties --common "--action modifyPage --space TEST --special \" #\" --findReplaceRegex \"xyz#<p>my test</p><p><br /></p><ac:structured-macro ac:name='include' ac:schema-version='1' data-layout='default' ac:macro-id='74fa2cb1-1e12-44ad-a17b-a810cb8cb943'><ac:parameter ac:name=''><ac:link><ri:page ri:content-title='@title@' ri:version-at-save='5' /></ac:link></ac:parameter></ac:structured-macro><p><br /></p>\""
Any hints?
ciao
ryder
Hi @ryder ,
We are from the Bobswift team. We have created a request on your behalf and would like to work with you over a Support Request 4403.
Thanks for signing up for the portal.
Amulya Akula
Register now
