Dear all,
I need to integrate automatically confluence with doxygen. Is it possible that?
Currently, I have to generate html file or pdf file from doygen, and afterawards, I have to import manually in confluence.
Thanks for your support.
Davide
Hi @Davide Ortenzi ,
I'm not familiar with Doxygen but there was another question about this integration that was resolved by using the HTML Macro.
You should have a look at the proposed solution here : https://community.atlassian.com/t5/Confluence-questions/Confluence-and-Doxygen-integration/qaq-p/1023160
Also, there is a request opened with Atlassian to have a native Doxygen integration, you can add a comment and vote for this feature here : https://jira.atlassian.com/browse/CONFCLOUD-43743
Let me know if this helps,
--Alexis
