Confluence built in approval document control?
Deleted user May 26, 2021
We have confluence cloud and were told there was an approval system for documentation.  For example, I assign John Smith to look at the document, make sure it's correct, then approve it.  Thus making it a confirmed document.
2 accepted
Capi [resolution]
Yeah, you will have to use an add-on. Comala Workflow is another great name in the marketplace, I believe it's now much easier to implement.
Apparently the app is now called Document Management. It's a good change, more specific to what it solves.
Pramoda Kumar Maharana
March 23, 2022
Good to know that, thanks for your information.
marc -Collabello--Phase Locked-
Hi @[deleted]
There is no built in approval system in Confluence Cloud.  However there are a couple of add-ons in the marketplace which make this possible.
For example, we make Document Control for Confluence Cloud , which allows you to designate reviewers and different types of signatures for approval.  There's a free trial.
After approval, you keep a record of when which document version was approved.
March 23, 2022
Very good !!!
James Conway
May 28, 2021
Hi @Capi [resolution] thanks for the recommendation!
Hi @[deleted], as @Capi [resolution] and @marc -Collabello--Phase Locked- have indicated, you will need an add in from the Marketplace.
If you want to learn more about Comala Document Management, you can check out our webinars
Kind regards
James
Senior Product Manager
Capi [resolution]
No worries @James Conway
Like • 2 people like this
Help us plant more trees
