I selected a large group of elements (shapes, text, images, post-its) and locked them using the padlock icon in the pop-up toolbar.
Now, I can’t select the group to unlock it.
The only option seems to be unlocking each item individually, which would take hours.
Is there a way to unlock the entire group at once?
Please advise.
Hey there @Fifield, Nick (WP) ,
You can right-click anywhere on your whiteboard and select 'Unlock all elements':
Hope this helps! =]
Mural uses Shift-Command + drag to include locked items in your selection. Great option.
Hi @Fifield, Nick (WP) ,
From what I know, Confluence whiteboards don’t currently have a way to unlock multiple locked items at once — each element has to be unlocked individually. It’s definitely a limitation when working with big groups.
One thing you could try is checking Atlassian’s feature requests or sharing feedback directly through the product, since bulk unlock would be a helpful improvement for many users.
Wish I had a better workaround, but hopefully Atlassian adds this in the future.
— Mia Tamm from Simpleasyty
