Copying spaces by exporting then importing
Brendan Andrews
If I export part of one space can I import it into another?
Essentially I want to copy part of one space to use as the basis for another. I don't want to commence the process in case it doesn't give me the option to choose which space to import the xml into and then modifies the source space inadvertently.
So.. will this work and will I be given the option to choose which space is the target of the import?
Jonathan Simonoff
June 9, 2015
I don't believe you can import a partial space or add things to a space – the space is specified in the XML export, and the imported space becomes a new space with that key (which must not exist before).
(When you export some pages from a space, it just becomes an export of the space with just those pages.)
I've read you can modify the key in the XML file, but I haven't tried it. Sounds like it would work.
Stephen Deutsch
June 10, 2015
Here's more information about the manual space copying process: https://confluence.atlassian.com/display/CONFKB/How+to+copy+or+rename+a+space+in+Confluence
Brendan Andrews
Thanks Stephen - though we use Confluence Cloud so that add-on won't help us.
Stephen Deutsch
June 10, 2015
I wasn't referring to the addon, if you look further down there is a step 2 that describes how to perform a manual copy of a space.
Brendan Andrews
Yes there is..! We've installed the paid plugin as a trial for now but I'll take a look at that for next time. Thank you!
Stephen Deutsch
June 10, 2015
I realize there is also a paid addon, I hope that works for you :)
Register now
