Create Issue from Confluence page, add more Jira fields to pop-up
Phil Harman
Is there a way to add more Jira fields to the pop-up window when I am using the Confluence page native process below?
  1. Select a block of text in Confluence page (Cloud)
  2. Hover over the selected text and click the Jira Macro button
  3. Select the correct project and issue type ... I do not see other fields like "due date" or "assignee" to fill in?
Joshua Sneed Contegix
July 27, 2020
Hi Phil,
I don't believe it is possible to add additional fields when creating issues from Confluence. Atlassian's documentation on Creating issues from Confluence indicate that only the Summary (highlighted text), project, issue type, and description are available. I looked in the marketplace and did not find any plugins to extend this functionality. Cheers!
Jared November 11, 2022
This is not true. I have a "teams field" when I create mine, but I cannot figure out how it got on there. Found this article because I am trying to add more fields.
Christian Schlaefcke
I think this is because you defined the Team field to be mandatory. See here ...
Lorien Anderson October 23, 2023
Hi, unfortunately, it is not true that  required fields automatically appear on the create pop up box from confluence (when creating a jira issue from confluence).
I would love an answer to this problem! Seriously, there’s must be a was to add a field to the create Jira issue from confluence box. Flowers and Candy to any accurate solutions. In Data Center, if possible.
Agathe.Valentini
November 29, 2023
