Create issues from Confluence, 'Link to Epic' is missing
Robert Obuch July 3, 2014
When I create JIRA issues from the product requirements template in Confluence, the 'Link to Epic' setting is missing.
Screenshot of feature that is missing is:
https://www.dropbox.com/s/jrdof96rymj4e9w/Screenshot_2014-07-04_16_34_29.png
This feature seems like it would be very valuable to have and I am unable to figure out how to get it to show.
Anybody have expierience in this area?
Tiago Comasseto
July 4, 2014
Hi Robert, you need to have an existing link to an Epic in the same Confluence page in order to see the opition to link issues with the Epic. http://awesomescreenshot.com/02333i7xd2
Cheers
Simon Deguire
July 3, 2015
It doesn't work for me, any idea?
image2015-7-3 13:54:40.png
Christian Ringgeler November 16, 2015
The descripted solution doesn't work for me as well. Epic link is embedded in the same confluence page but when I pull up the "create issue" dialog no epic link checkbox is shown.
walter April 27, 2020
7years later, does it work now?
i meet the problem too
Ahad_Zakir_Khan
June 9, 2020
Hi guys - I am still facing this issue. Any idea when this is planned to be fixed?
I checked the link share by Adam_Reid which mentions that this issue has been fixed but I am still facing it.
Andréas Johansson August 18, 2020
I'm having the same problem, using Jira and Confluence Cloud
For me it seems that if I create a page and add a single epic link to it, then it works as expected. But after adding a second epic link it stops working. Removing the link makes no difference.
Had a similar experience with the Product Requirements Blueprint
Adam Reid
May 24, 2018
There is an actual problem in confluence where the above answer may not be the resolution. See https://jira.atlassian.com/browse/CONFSERVER-41078
This is affecting me on Confluence server 6.9.0 linked with JIRA 7.9.2
Register today
