To change the fields/wording that shows on an incident in the customer portal, you'll need to do the following:
I hope this helps!
Kian
Thanks for that. Jira Service Desk has been set up by a consultant. It works but there are these little tweaks which weren't thought of during project. I have found it as I carefully went deeper into that area. Your instructions are really helpful. Thank you :)
