Hello Confluence admins,
I have recently upgraded Confluence from 7.19.17 to 8.5.12.
This is a two node cluster and has been working just fine until the upgrade.
The cluster is connected to an SQL server and uses kerberos to authenticate.
Below the configuration used and modified to remove sensitive info.
The pool size has been 60 for the last few years and I have increased it to 80 in an attempt to stabilize the service
<property name="hibernate.c3p0.max_size">80</property>
<property name="hibernate.c3p0.validate">true</property>
<property name="hibernate.connection.autocommit">false</property>
<property name="hibernate.connection.driver_class">com.microsoft.sqlserver.jdbc.SQLServerDriver</property>
<property name="hibernate.connection.isolation">2</property>
<property name="hibernate.connection.password">REDACTED</property>
<property name="hibernate.connection.provider_class">com.atlassian.confluence.impl.hibernate.DelegatingHikariConnectionProvider</property>
<property name="hibernate.connection.url">jdbc:sqlserver://HOST:PORT;databaseName=DATABASE;domain=DOMAINNAME;integratedSecurity=true;authenticationScheme=JavaKerberos</property>
<property name="hibernate.connection.username">REDACTED</property>
<property name="hibernate.database.lower_non_ascii_supported">true</property>
<property name="hibernate.dialect">com.atlassian.confluence.impl.hibernate.dialect.SQLServerDialect</property>
<property name="hibernate.hikari.idleTimeout">30000</property>
<property name="hibernate.hikari.maximumPoolSize">80</property>
<property name="hibernate.hikari.minimumIdle">20</property>
<property name="hibernate.hikari.registerMbeans">true</property>
<Connector port="8080" connectionTimeout="20000" redirectPort="8443"
maxThreads="48" maxPostSize="16777216" minSpareThreads="10"
maxHttpHeaderSize="24578" enableLookups="false" acceptCount="10" URIEncoding="UTF-8"
protocol="org.apache.coyote.http11.Http11NioProtocol"
scheme="https" secure="true" proxyName="confluence.domain.tld" proxyPort="443" />
At least twice a day one of the two nodes will stop responding. Sometimes they both stop responding. The logs fill up with 'Unable to aquire JDBC Connection' due to no connections in the pool, due to No loginModule found. (See Exception Exanmple below)
The DBA team are confident there are no issues and they do not see failed authentication attempts.
Restarting Confluence brings the node online and it starts accepting traffic, logs indicate normal operation
The bundled SQL Server driver is used and quite old (7.4) mssql-jdbc-7.4.1.jre8.jar
From the database-jdbc-drivers documentation
We recommend that you use the bundled Type 4 JDBC driver.
If you decide to use a later version, we may not be able to provide support for any problems you encounter.
The bundled jar is only for java 8 if it does hwat it says on the tin
I do not find a bundled version of Java in the gunzip archive
Confluence version | Supported Java vendors | Bundled Java vendor |
7.13.2 to 7.13.x, and 7.14.1 to latest | Oracle JDK/JRE | Eclipse Temurin |
EDIT:
From supported-platforms the JRE is not expected to be in the gunzip file. It is only in the installer
Good to know:
END EDIT
2024-08-12 01:31:30,166 WARN [Caesium-1-4] [confluence.impl.search.IndexFlushScheduler] lambda$new$1 Failed to flush index queue LuceneContentIndexFlusher, retry in 10s
org.springframework.transaction.CannotCreateTransactionException: Could not open Hibernate Session for transaction; nested exception is org.hibernate.exception.JDBCConnectionException: Unable to acquire JDBC Co
nnection
at org.springframework.orm.hibernate5.HibernateTransactionManager.doBegin(HibernateTransactionManager.java:600)
at com.atlassian.confluence.impl.hibernate.ConfluenceHibernateTransactionManager.doBegin(ConfluenceHibernateTransactionManager.java:31)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.startTransaction(AbstractPlatformTransactionManager.java:400)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.getTransaction(AbstractPlatformTransactionManager.java:373)
at jdk.internal.reflect.GeneratedMethodAccessor125.invoke(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:344)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:234)
at com.sun.proxy.$Proxy107.getTransaction(Unknown Source)
at org.springframework.transaction.interceptor.TransactionAspectSupport.createTransactionIfNecessary(TransactionAspectSupport.java:595)
at org.springframework.transaction.interceptor.TransactionAspectSupport.invokeWithinTransaction(TransactionAspectSupport.java:382)
at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:119)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:186)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:241)
at com.sun.proxy.$Proxy239.flushQueue(Unknown Source)
at com.atlassian.confluence.impl.search.IndexFlushScheduler.lambda$new$1(IndexFlushScheduler.java:122)
at com.atlassian.confluence.impl.schedule.caesium.JobRunnerWrapper.doRunJob(JobRunnerWrapper.java:121)
at com.atlassian.confluence.impl.schedule.caesium.JobRunnerWrapper.runJob(JobRunnerWrapper.java:83)
at com.atlassian.scheduler.core.JobLauncher.runJob(JobLauncher.java:134)
at com.atlassian.scheduler.core.JobLauncher.launchAndBuildResponse(JobLauncher.java:106)
at com.atlassian.scheduler.core.JobLauncher.launch(JobLauncher.java:90)
at com.atlassian.scheduler.caesium.impl.CaesiumSchedulerService.launchJob(CaesiumSchedulerService.java:464)
at com.atlassian.scheduler.caesium.impl.CaesiumSchedulerService.executeLocalJob(CaesiumSchedulerService.java:431)
at com.atlassian.scheduler.caesium.impl.CaesiumSchedulerService.executeQueuedJob(CaesiumSchedulerService.java:409)
at com.atlassian.scheduler.caesium.impl.SchedulerQueueWorker.executeJob(SchedulerQueueWorker.java:66)
at com.atlassian.scheduler.caesium.impl.SchedulerQueueWorker.executeNextJob(SchedulerQueueWorker.java:60)
at com.atlassian.scheduler.caesium.impl.SchedulerQueueWorker.run(SchedulerQueueWorker.java:35)
at java.base/java.lang.Thread.run(Thread.java:829)
Caused by: org.hibernate.exception.JDBCConnectionException: Unable to acquire JDBC Connection
at org.hibernate.exception.internal.SQLExceptionTypeDelegate.convert(SQLExceptionTypeDelegate.java:48)
at org.hibernate.exception.internal.StandardSQLExceptionConverter.convert(StandardSQLExceptionConverter.java:37)
at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:113)
at org.hibernate.engine.jdbc.spi.SqlExceptionHelper.convert(SqlExceptionHelper.java:99)
at org.hibernate.resource.jdbc.internal.LogicalConnectionManagedImpl.acquireConnectionIfNeeded(LogicalConnectionManagedImpl.java:111)
at org.hibernate.resource.jdbc.internal.LogicalConnectionManagedImpl.getPhysicalConnection(LogicalConnectionManagedImpl.java:138)
at org.hibernate.internal.SessionImpl.connection(SessionImpl.java:516)
at org.springframework.orm.hibernate5.HibernateTransactionManager.doBegin(HibernateTransactionManager.java:502)
... 28 more
Caused by: java.sql.SQLTransientConnectionException: HikariPool-1 - Connection is not available, request timed out after 30000ms.
at com.zaxxer.hikari.pool.HikariPool.createTimeoutException(HikariPool.java:696)
at com.zaxxer.hikari.pool.HikariPool.getConnection(HikariPool.java:197)
at com.zaxxer.hikari.pool.HikariPool.getConnection(HikariPool.java:162)
at com.zaxxer.hikari.HikariDataSource.getConnection(HikariDataSource.java:100)
at org.hibernate.hikaricp.internal.HikariCPConnectionProvider.getConnection(HikariCPConnectionProvider.java:77)
at com.atlassian.confluence.impl.hibernate.DelegatingHikariConnectionProvider.getConnection(DelegatingHikariConnectionProvider.java:48)
at jdk.internal.reflect.GeneratedMethodAccessor237.invoke(Unknown Source)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:198)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:163)
at org.springframework.aop.framework.adapter.MethodBeforeAdviceInterceptor.invoke(MethodBeforeAdviceInterceptor.java:58)
at org.springframework.aop.framework.adapter.ThrowsAdviceInterceptor.invoke(ThrowsAdviceInterceptor.java:113)
at com.sun.proxy.$Proxy743.getConnection(Unknown Source)
at org.hibernate.internal.NonContextualJdbcConnectionAccess.obtainConnection(NonContextualJdbcConnectionAccess.java:38)
at org.hibernate.resource.jdbc.internal.LogicalConnectionManagedImpl.acquireConnectionIfNeeded(LogicalConnectionManagedImpl.java:108)
... 31 more
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Kerberos Login failed: Integrated authentication failed. ClientConnectionId:bc429792-b23f-4c23-9af8-b98f1a769208 due to javax.security.auth.login.Logi
nException (No LoginModule found for com.sun.security.auth.module.Krb5LoginModule)
at com.microsoft.sqlserver.jdbc.KerbAuthentication.intAuthInit(KerbAuthentication.java:100)
at com.microsoft.sqlserver.jdbc.KerbAuthentication.generateClientContext(KerbAuthentication.java:207)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.sendLogon(SQLServerConnection.java:4820)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.logon(SQLServerConnection.java:3731)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.access$000(SQLServerConnection.java:94)
at com.microsoft.sqlserver.jdbc.SQLServerConnection$LogonCommand.doExecute(SQLServerConnection.java:3675)
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7194)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:2979)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectHelper(SQLServerConnection.java:2488)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.login(SQLServerConnection.java:2142)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connectInternal(SQLServerConnection.java:1993)
at com.microsoft.sqlserver.jdbc.SQLServerConnection.connect(SQLServerConnection.java:1164)
at com.microsoft.sqlserver.jdbc.SQLServerDriver.connect(SQLServerDriver.java:760)
at com.zaxxer.hikari.util.DriverDataSource.getConnection(DriverDataSource.java:138)
at com.zaxxer.hikari.pool.PoolBase.newConnection(PoolBase.java:364)
at com.zaxxer.hikari.pool.PoolBase.newPoolEntry(PoolBase.java:206)
at com.zaxxer.hikari.pool.HikariPool.createPoolEntry(HikariPool.java:476)
at com.zaxxer.hikari.pool.HikariPool.access$100(HikariPool.java:71)
at com.zaxxer.hikari.pool.HikariPool$PoolEntryCreator.call(HikariPool.java:726)
at com.zaxxer.hikari.pool.HikariPool$PoolEntryCreator.call(HikariPool.java:712)
at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
... 1 more
Caused by: javax.security.auth.login.LoginException: No LoginModule found for com.sun.security.auth.module.Krb5LoginModule
at java.base/javax.security.auth.login.LoginContext.invoke(LoginContext.java:731)
at java.base/javax.security.auth.login.LoginContext$4.run(LoginContext.java:672)
at java.base/javax.security.auth.login.LoginContext$4.run(LoginContext.java:670)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at java.base/javax.security.auth.login.LoginContext.invokePriv(LoginContext.java:670)
at java.base/javax.security.auth.login.LoginContext.login(LoginContext.java:581)
at com.microsoft.sqlserver.jdbc.KerbAuthentication.intAuthInit(KerbAuthentication.java:77)
... 23 more
The ms-sql driver shipped is now EOL and it is also for Java 8.
The error is due to the way Java 8 and Java 11 use ForkJoinPool.
:( If you are using MS SQL then Confluence is not really compatible with Java 11.
See inside
