I have successfully created a Confluence page that includes a “code block” macro via REST API. In the body of the API call I use “representation” = “wiki”, then, the code block starts with “{code:linenumbers=true|firstline=0001|collapse=true}”.
I read that the “code block” macro (and others) will be DA on Feb 2026. Recommendation is to use the “code snippet” element.
This document shows how to use the new “code snippet” from GUI. I am unable to find information about doing this programmatically via REST API… Any leads/ideas?
Thank you in advance.
