Document Management Question
Todd Sandeman June 21, 2022
Is there a report/filter, or anything that will allow me to, in Confluence Cloud, see a list of documents saved in a specific space, the date it was last edited, and other such metadata? If not, do you have ideas on how to do so?  Thank you!
marc -Collabello--Phase Locked-
Hi @Todd Sandeman ,
Maybe this app can help: https://marketplace.atlassian.com/apps/1226276/keep-it-up-to-date
It's free and simple to use, but I'm not sure if it matches your use case.
Nic Brough -Adaptavist-
June 21, 2022
The answer does depend on what you mean by "document".
If you mean "document = page", the way a wiki like Confluence is supposed to be used, then yes, there are loads of ways of looking at the metadata for a page - macros, reports, page lists, searches, all expose different bits of the metadata.
If you mean "document = attachment", then, no, not really.  You can get lists of attachments, but because it's not a document store, there's not a lot of metadata.  Go to "space settings" -> content -> attachments, for a list, the attachment location,  size, created and last edited date author and labels.  There isn't a lot more to them.
Nic, thank you for the reply! When I say Document, I mean a "Page". That is what I am searching for.
