×Hi,
i am not sure if i am right here with my questions but i will just try and ask
Regarding the security settings for the Atlassian Cloud i came across the BYOK settings within the security settings.
Is it possible to configure this also with the Micrsoft Azure Vault Key or does this only work with the AWS Key vault?
I couldn't find any information regarding this.
Sorry if this question is not in the right category.
Thanks in advance
Microsoft Azure Key Vault is not currently supported for BYOK in Atlassian Cloud.
To learn more - Introducing bring-your-own-key encryption (BYOK) | Atlassian
Hope this helps - Happy to help further!!
Thank you very much and have a great one!
Warm regards
Hi thank you for your answer.
I hoped for an clean overview which Vaults are supported.
However my question is answered :).
