Drop down values started showing borders around and edit / delete buttons
Marina Laysha
I just noticed that drop down values on my form started showing borders around and edit / delete buttons. Is this a new feature after the upgrade? Can I turn this off?
I just want a simple drop down with simple values compact display as it used to be.
Marc - Devoteam
July 30, 2025
Hi @Marina Laysha
Do you mean JSM Form or options on the work type seen as an agent?
Marina Laysha
this is a business project,  so there are no form, but rather a list of "Select List (single choice)" fields
Like Marc - Devoteam likes this
Marc - Devoteam
July 31, 2025
Hi @Marina Laysha
I can't see this.
If I select an option or multiple, they appear with borders, but not in the select.
Can you check the field type of this custom field, what type is it?
Or could it be field types from a 3rd party app on the system?
Otherwise reach out to Atlassian Support
July 31, 2025
Hi @Marina Laysha and @Marc - Devoteam
I was able to reproduce this with a team-managed, project-specific custom selection field.
This does not happen when adding a global / company-managed, custom selection field to a team-managed project.
This change has the same recently added behavior as Labels (in all project types / scopes) to allow color-coding by values.
