Hello!
I have to apply auto filter on the dropdown field bsaed on the checkbox group.
For example when a person mark Java and Python in the next field only those two field should appear. I found similar topic but I don't know how the condition in "Filter to apply on a field" should look like.
What field type is the field "Jezyk Glowny"? A multi-select?
What should happen when you select multiple in the checkbox group field?
In the dropdown should appear a list with all checked fields in the checkbox. But I should chose only one option (that's why dropdown "Jezyk Glowny")
id:[entry.Jezyki.transform(id).join( OR id:)]
Yes, it is a filtering expression
The condition of "Jezyki:true" - what is it? What is should do? Jezyki is a checkbox group, why do you check it to be with value "true"?
Can I filter similar way the related dropdown?
Let's say I have one dropdown with MPK and second with combined user+MPK. And I want to narrow output of the second field to the MPK choosen ealier. The condition would be similar? The fields are Database dropdown advance
This on the other hand is working but retrives only one person, while there might be many more so I need to render a list.
Should not you filter the second dropdown by "MPK"? not by ID...
What is the SQL you have for the second dropdown? Do you select the "MPK" in the query?
I think I have helped you with the very same on a different question you have asked...
Do you want to filter by the ManagerID?
yes, you're right but I switched to another form as I'm working on a few of them right now. The solution didn't work previously, so I left it. The case is similar I think as in the topic for checkbox.. and the solution for checkbox worked
I need to filter based on MPK. The output of 'WybierzWakat' (which is Name + MPK) should be narrow to the MPK choosen in 'ZrodloLimitu'
I still dont get it - what FIELD in the SQL query is MPK?
MPK = [Employee MPK]
for the first filed it's ID as well as output of the field for the sceond field it is placed as a description e.g. Name + MPK (combined)
No, sorry
Give me the example of what selects the first query and what selects the second and how the second should be filtered out
It should be like this but with the list of all people with the chosen MPK (right now it's filtering only one which is incorrect)
Give me the EXAMPLES
2 tables that show the subset of data with column names for EACH dropdown and show how the second dropdown should be filtered (using WHICH field from the query/table)
I dont need your real data, I just want to understand what DATA do you get from those 2 queries
To be able to link them together and (finally) help (loosing my hope already)
You know what a TABLE is, right?
I will give you an example
Assuming the first query returns (field name is field1)
SELECT DISTINCT mpk as id, name FROM SecretTable
id | name |
1 | MPK 1 |
2 | MPK 2 |
And the second returns (field name in ConfiForms is field2)
SELECT id, label, mpk FROM SecretTable
id | label | mpk |
1 | Hello | 1 |
2 | Beautiful | 2 |
3 | World | 1 |
In order to filter the second dropdown I would have an "Apply filter on filed" rule with a filtering expression like
mpk:[entry.id]
Alex
See inside
