Dynamic Filtering of a Smart Dropdown Based on Populated Field in Confiforms
Chris Iacovelli
October 22, 2025
i have a source page (P1) with a confiform that contains 3 fields, archCode, archDesc, and archType.
  • archCode is a unique code to identify the entry.
  • archDesc is the description.
  • archType is the flag to identify if it is a major item (1), minor item (2), or trivial item (3).
the items stored in this table are numerically encoded to capture the relationship of major to minor to trivial items:
  • archCode XX.01 for a major item
  • archCode XX.01.01 for a minor item
  • archCode XX.01.01.01 for a trivial item
on a differing page (P2), i have 2 smart dropdowns (archCodeMajor and archCodeMinor) which use the items from P1.
  • the first drop down filters the list presented to all entries where the archType is major (1), e.g., CD.01 (Apply filter on choices is "archType:1").
  • the second drop down intends to filter the list presented to all entries where the archType is minor (2) and the archCode is arcCodeMajor with the literal ".*" appended to the end of the entered value, e.g., CD.01.* (Apply filter on choices is "archCodeMinor:[entry.arcCodeMajor.archCode.append(.*)] AND archType:2").
first drop down works without issue.
second drop down returns a message stating there is no matches. the portion of the filter [entry.arcCodeMajor.archCode.append(.*)] renders as expected as i dropped the value into a readonly field for inspection.
when i removed the .archCode portion i am presented with a list of all minor items (2).
not sure what i am doing wrong here.
