EpicLink column empty in Confluence macro but not on related filter
Marc-André Lanciault
I have created a Jira filter which I'm using in a Confluence Macro. One of the column use in both places is the EpicLink column.
Here is a screenshot of the filter:
And here is a screenshot of the Confluence Macro using this very filter:
The tickets are displayed correctly in the Macro, but the Epic Link is empty, where it has data in the filter.
Anyone can help ? Thanks!
Utkarsh Agarwal
Hi @Marc-André Lanciault ,
Looks like you are affected by either of these bugs:
CONFCLOUD-43561: Epic Link column in Confluence's "Insert JIRA Issue/Filter" is not displayed properly
CONFCLOUD-51568: JIRA issues Macro instead of Epic Name showing Epic Link column
I would suggest you click on the 'This affects my team' to get this prioritized.
Kind Regards
Utkarsh
It seems like it yes. Will do that, Thanks!
