Hy, I got an error on the configuration site of draw.io.
I installed draw.io on several free accounts but I get always the same error.
I can create a draw element but when I will put it to an article I get an error. The draw element will not found.
I think it is a problem with the space configuration.
It was a problem with Kaspersky firewall...
"Yes, Kaspersky anti-virus has started blocking the domains api.media.atlassian.com and media.atlassian.com.
In case you’d like to continue to use the anti-virus, you can manually allow these domains. This should help."
Hi @Matthias Ludwig ,
Please reach out to our support team: https://drawio-app.com/support/
They will be able to help you resolve this error.
Have a good day!
Have you reached out to draw.io support as yet? They might be able to assist more quickly on this error.
Read more 📚Online forums and learning are now in one easy-to-use experience.
