Error of PlantUML Diagrams for Confluence Macro
yasushi.nagao May 18, 2020
I tried PlantUML Diagrams for confluence macro. I wrote simple sequence figure in Definition field and pushed the preview button. This macro displayed error message which was "Could not generate preview. Please consult tech support."
My co-worker could use this macro on the last November. He used this today(19,May JST) on the same confluence cloud environment. And he got same error message.
Please check this behavior.
Thank you very much for your help,
Yasushi Nagao,
2 accepted
Boris Jockov
Hi Yasushi,
We are aware of the problem and we're working on a fix.
Update : the problem has been resolved.
Boris.
Allan Ortiz
May 20, 2020
Thank you for the quick fix!  This issue also affected me so I am glad to say thanks!
yasushi.nagao May 20, 2020
Hi Boris,
I can use it without problems.
I appreciate your fantastic works.
Thank you,
Yasushi,
David Benson _draw_io_
May 19, 2020
Which plugin is it you're using?
yasushi.nagao May 19, 2020
I tried to use the following plugin.
Thank you very much for your quick response,
Divyata Sharma April 21, 2021
I am facing the same issue now. Can someone check it?
