Hello Community, anyone knows why this is happening? Last week it was working fine and we had no tickets comming in.
@MidnightExe The error message means that the SQL Server JDBC Driver is not found on the Java classpath. In other words, the DB driver is not available for Confluence, therefore cannot connect to the DB and cannot run SQL queries.
Isn't this possible that it broke because you upgraded your Confluence version and forgot about the JDBC driver?
By the way, here is another topic that has similar symptoms: https://community.atlassian.com/forums/Confluence-questions/Is-sqljdbc-auth-dll-valid-for-8-5-20-DC/qaq-p/2981552
Hei @Aron Gombas _Midori_ we managed to fix the issue. Yes we found that the driver was missing in the config. Now it's running fine.
Still, thanks for the reply!
