I have these (estimated/Actual benefits) set up against OKRs Ive linked to JIRA tickets, but I can't find the fields that they relate to and cant see them to be added in on the config settings? They are being pulled from somewhere, so wondered if they were accessible. I want to use them for benefits realisation on a page. Thanks
Hi @Jonathan Batcock ,
can I assume that that image is taken from a filter result where you have the columns being displayed? In any event have you gone to the administration section under issues then custom fields and look for these two fields? If they aren't there is it possible that this is associated with some add-on?
Hi @Jonathan Batcock - did you get a resolution to your question?
