Export Post Incident review to confluence template
Michael
Does anyone know if its possible to change the template when it exports ?
Sayed Bares [ServiceRocket]
@Michael can you explain further on what you are trying to achieve? if you want to edit the Post Incident review template in Confluence then yes that is possible:
Róbert Szabó
I think Michael is referring to this function of JSM:
https://support.atlassian.com/jira-service-management-cloud/docs/create-and-publish-a-post-incident-review/
And how to modify the PIR Confluence export template.
