Export WhiteBoard (images in white)
Arnau Barbecho Barrado
Hello!
I'm trying to export a WhiteBoard with some pictures, but when i export the WhiteBoard into jpg or png some pictures are in white.
I tried with GoogleChrome and another browser (Edge), but i have the same problem.
Any idea?
Thanks to all community!
2 accepted
Rajat Pratap Singh _DHL IT Services_
August 28, 2025
Hi @Arnau Barbecho Barrado
Few things to try:
  • Increase the zoom level of the Whiteboard and then try to export.
  • Check if the pictures in the Whiteboard are not linked from an external URL. If so, upload the images directly as attachments on the whiteboard page.
  • Check the extensions of the images in the whiteboard. If png, convert the to jpeg and then try to export.
Hope this helps!
Regards
Rajat
We increased the zoom level and then works.
I don't know why,.
Shreeja J
August 28, 2025
Thanks for sharing the screenshots!
From what I can see is the images display fine on the Whiteboard itself, but they turn blank when exporting to JPG/PNG.
A few things you can try:
  • Clear your browser cache and re-export
  • Re-upload the images directly to the Whiteboard
  • Try exporting as PDF (if available)
If it still doesn’t work, this might be a bug/limitation with Whiteboard export. I’d recommend raising a support ticket with Atlassian and attaching the before/after screenshots you already have so that they can investigate further.
Shreeja
Shreeja J
August 27, 2025
Hello @Arnau Barbecho Barrado
To better understand the issue, could you please share a screenshot of how the Whiteboard looks before and after export?
Shreeja
Hello @Shreeja J
Here you have an example:
Before export:
After export: (format JPG)
Thiago P _Atlassian Support_
August 28, 2025
Hey there @Arnau Barbecho Barrado ,
Do you know if the image files added to this Whiteboard have different extensions (such as .jpg, .webp, .gif etc.) by any chance?
Notice that 'B "Vuelo"' and 'D Variador F.' work as expected, but 'CM_CKST' and 'A Estatica' do not.
Like Barbara Szczesniak likes this
Hello @Thiago P _Atlassian Support_ ,
We try with .jpg and .png, and with both we have the same problem. In this case, all pictures are .jpg, and we try to export to jpg and png.
When we increase the zoom level, as says @Rajat Pratap Singh _DHL IT Services_ then works.
August 28, 2025
That's great!
Either way, please open a Support ticket so our Team can investigate this and open a new Bug (or point you to an existing one).
Like Arnau Barbecho Barrado likes this
I opened a Support ticket and there was a bug, but now Atlassian Team has solved it and now works fine.
September 17, 2025
Glad to hear!
Thank you for reporting this to our Team =]
Vishalakshi Narayana Swamy
September 17, 2025
I am glad the issue is now resolved.
Hence I shall go ahead and close this request for now since this is being followed up through a support ticket already.
Have a great day ahead!
Best Regards,
Vishalakshi Narayanaswamy
Hello @Vishalakshi Narayana Swamy ,
Yes, it's already solved. Thanks.
