Hi community!
I'm facing an issue when I'm trying to create a page on confluence cloud using API v2.
When I use this
GET 'https://companyname.atlassian.net/wiki/api/v2/pages'
I have results correctly but when I use the API to create a new page I have 404
POST
with this body
As mentioned here:
https://developer.atlassian.com/cloud/confluence/rest/v2/api-group-page/#api-pages-post
404 Not Found
Returned if:
Check the space permissions.
Ive tested this:
https:/my.atlassian.net/wiki/api/v2/pages with a POST and this body and it works.
"spaceId": "33009",
"status": "current",
"title": "Interesting page title",
"parentId": "33096",
"body": {
"representation": "storage",
"value": "<p>The page content</p>"
Regards
Aaron
Thanks @Aaron Pavez _ServiceRocket_ for your quick reply.
Can you help my on checking my permission? Because with my user I can create pages on the space so I don’t know where the problem about permissions is.
thanks again
Can you test the body I used? On yours, you are missing this:
Hi @Aaron Pavez _ServiceRocket_ yes I used also the same body you used but same error.
I’m using my API token the same I use for the other API (get pages) that works.
Maybe I’m wrong with the space and parent id? Is there a friendly way to get them, I mean get them directly from Confluence pages?
Hi again!
The Space ID? Not from the UI, only with API.
/wiki/rest/api/space/SPACEKEYHERE
Double check the space ID and parent page ID.Y
You can get the page ID from the UI by going to More actions -> Advanced details -> Page information
Regards
Nope :/
Hi!
Can you try the curl command from the Atlassian page?
curl --request POST \
--url 'https://{your-domain}/wiki/api/v2/pages' \
--user 'email@example.com:<api_token>' \
--header 'Accept: application/json' \
--header 'Content-Type: application/json' \
--data '{
"spaceId": "<string>",
"title": "<string>",
"parentId": "<string>",
"body": {
"value": "<string>"
Regards
@Aaron Pavez _ServiceRocket_ now it works, I don't know how but in postman I had a problem with my token :(
Thanks for the support!
Hi!
How? I'm using the curl with Postman but don't know how to use it in the Atlassian page :/
With postman you dont need to user curl.
add the URL
in authorization
- Username: use your email
- Password: your token
the body is the one I've shared earlier. select raw and JSON at the end.
That should do it.
regards
Here you have:
1) the API that works (Get Pages)
2) the API that doesn't work (Create Page)
Same url, same user, same API token ...
Hi , I am also experiencing the same issue this is my schema. I am facing the 404 issues in the backend when I try to find the space using the id. In the postman I am using the basic auth but in the schema below ouath-bearer auth. The api are
https://name.atlassian.net/wiki/api/v2/spaces?keys=name (get)
https://name.atlassian.net/wiki/api/v2/pages (post).
Have i made a mistake here?
openapi: 3.1.0
info:
title: Atlassian Confluence API
version: 1.0.0
servers:
- url: https://sample.atlassian.net/wiki/api/v2
- description: Confluence Server
paths:
/spaces:
get:
operationId: getSpaceInformation
summary: Retrieve space information
parameters:
- in: query
required: true
schema:
type: string
description: The key of the space to retrieve
responses:
'200':
description: Success
content:
application/json:
schema:
type: object
properties:
id:
type: string
security:
- bearerAuth: []
/pages:
post:
operationId: createPage
summary: Create a new page
requestBody:
required: true
content:
application/json:
schema:
type: object
properties:
spaceId:
type: string
status:
type: string
title:
type: string
parentId:
type: string
body:
type: object
properties:
representation:
type: string
example: storage
value:
type: string
required:
- spaceId
- status
- title
- body
responses:
'200':
description: Page created successfully
security:
- bearerAuth: []
components:
securitySchemes:
bearerAuth:
type: http
scheme: bearer
bearerFormat: JWT
Help us plant more trees
