I try to fetch the consumed storage of our spaces by using the python script as documented here: https://confluence.atlassian.com/confkb/finding-storage-usage-of-confluence-space-and-page-using-rest-api-1063555292.html
The script is running fine but stops after 25 spaces. I can't find any limiter within the script, so maybe the REST API is limiting.
Can somebody help me out how to fetch all results?
Jonny
It seems the python script does not follow the `_next` links, if there are more than 25 results.
I believe the script needs to be modified for this.
Hi There,
is there anyone who has already updated the script?
Patrick
I got the Solution and edited the Script to get 500 results:
# This code sample uses the 'requests' 'json' 'csv' library: import requests import json import csv #INSERT "USER", "TOKEN", "BASE_URL" HERE USER="User" TOKEN="Token" BASE_URL="https://xxxxxxxxx.atlassian.net" with open('per_page.csv', 'w') as pagecsvfile, open('per_space.csv', 'w') as spacecsvfile: perPageWriter = csv.writer(pagecsvfile, delimiter=',', quotechar='|', quoting=csv.QUOTE_MINIMAL) perSpaceWriter = csv.writer(spacecsvfile, delimiter=',', quotechar='|', quoting=csv.QUOTE_MINIMAL) perPageWriter.writerow(['pageid','attachment_size(byte)']) perSpaceWriter.writerow(['space_name','space_key','attachment_size(byte)']) headers = { "Accept": "application/json" } response = requests.request( "GET", BASE_URL + "/wiki/rest/api/space?limit=500", headers=headers, auth=(USER,TOKEN) ) site_attachment_volume = 0 #Get all space keys space_key_results = json.loads(response.text)["results"] for space in space_key_results: space_attachment_volume = 0 #Get related page IDs from space keys response = requests.request( "GET", BASE_URL + "/wiki/rest/api/space/" + space["key"] + "/content", headers=headers, auth=(USER,TOKEN) ) print("Space Key: " + space["key"]) page_results = json.loads(response.text)["page"]["results"] for page in page_results: page_attachment_volume = 0 #Get attachments from each page print(" " + "Page ID: " + page["id"]) response = requests.request( "GET", BASE_URL + "/wiki/rest/api/content/" + page["id"] + "/child/attachment", headers=headers, auth=(USER,TOKEN) ) attachment_results = json.loads(response.text)["results"] for attachment in attachment_results: print(" " + "Attachment Name: " + json.dumps(attachment["title"]) + ", " + json.dumps(attachment["extensions"]["fileSize"]) + " bytes") page_attachment_volume += int(json.dumps(attachment["extensions"]["fileSize"])) space_attachment_volume += page_attachment_volume print(" -->" + "PAGE TOTAL: " + str(page_attachment_volume)) #Write to CSV perPageWriter.writerow([page["id"],str(page_attachment_volume)]) print("\n " + "SPACE TOTAL: " + str(space_attachment_volume) + " bytes") print("----------") #Write to CSV perSpaceWriter.writerow([space["name"],space["key"],str(space_attachment_volume)])
Hi there,
Would anyone be able to assist with updating this script to work with the v2 api from Atlassian for Confluence? Reason being I can use the pagination and response header to pull more than 250 requests which I need due to the amount of spaces.
I have updated the endpoints but am receiving the below error:
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/json/__init__.py", line 346, in loads
return _default_decoder.decode(s)
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/Library/Frameworks/Python.framework/Versions/3.11/lib/python3.11/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 3 column 1 (char 10)
Jan
Probably it is some programming work, as the v2 API is different from v1.
Do you need the output on the command line? Or is output in a table in Confluence also ok?
Ideally if it could be in the same format where it saves to a CSV would be great, I only actually require the per_space.csv and not individual pages if that helps.
I am also not sure how the response header works in python as I have already have the command working for Get/Spaces working in Postman with the v2 api and see the response header at the bottom.
Jan
Read more 📚Online forums and learning are now in one easy-to-use experience.
