Gliffy: Shapes are automatically connecting to Arrows.
Ankit Sinha
June 18, 2024
I am trying to add shapes over existing arrows. I do not want this new shape to automatically break the arrows into two and get connected. I only want to place this shape over the diagram. I am facing this issue since today.
Samie Kaufman - Your Gal at Gliffy
June 18, 2024
Hi @Ankit Sinha ! You're correct that this is a change we recently implemented in Gliffy Diagrams for Confluence Cloud. The intention is to make it easier to build out your diagram, but I understand that it's an adjustment to get used to as an existing Gliffy user!
Would you mind reaching out to me directly so that I can review the specific behavior you're experiencing and make sure things are working as expected for you? I can also get some details about the auto-disable option you suggested and log that as a request.
My email is skaufman@perforce.com. :)
Bastian -drawio Diagrams-
Hey Ankit. Which tool are you talking about? Confluence whiteboards or a diagramming app?
Ankit Sinha
June 18, 2024
Gliffy for Confluence cloud. I noticed some new update was released:
What’s New in Gliffy’s Confluence & Jira Apps | Gliffy by Perforce
Basically I want to disable this auto-feature
Hi Ankit. Unfortunately, I can't provide a solution, as it's not one of our features. But our colleagues at Gliffy will probably help you out soon :)
June 18, 2024
Jinx, @Bastian -drawio Diagrams-😉 Happy Tuesday!
