×Viewing Confluence Cloud pages on Windows with the side menu enabled, you always see a vertical scroll bar when the side menu has focus.
In MACOS, the vertical scroll bar is not visible for the side menu when it has focus.
Is there a key combination I can use to show the side scroll bar on MACOS?
I don't see a configuration option for this.
Jim Mason
