Ho do i set-up application links between Confluence and Jira
Samuel Charpentier December 19, 2022
Hey, i have set-up application tunnel, I don’t know where can I find each data when i try to configure the application links.
Could you help me please?
Alex Koxaras -Relational-
Hi @Samuel Charpentier
Are you trying to connect JSM to Confluence cloud? If yes and you want to use it as a KB, then there is another way to do it, and not via application tunnel.
Samuel Charpentier February 2, 2023
Yes, what else can be done?
Adrien Low [ServiceRocket]
Hello @Samuel Charpentier ,
Are both of your applications on Cloud?
Can you try following the steps as outlined in the KB below?
Regards.
Samuel Charpentier December 20, 2022
No Jira is a server instance, but Confluence is on the Cloud.
Thank you
FREE
