How do I add Page Feedback for Confluence Macro as a footer?
Brandi Guess
November 6, 2023
I want to add page feedback to all my pages in our user-facing knowledge base.  I COULD manually insert the macro on every page, but that seems like a lot of manual work and there should be a better way.  Anyone ever done this? Is putting it in the footer the way to go? Is there another way that may be better?
Dr. Adrian Hülsmann - B1NARY
I am happy to announce the release of Peacock - better content quality for Confluence Cloud.
As mentioned above, it sounds like a perfect fit for your use case @Brandi Guess
Best regards, Adrian from B1NARY (we are the developers of Peacock)
Hello @Brandi Guess ,
your use case sounds like a perfect fit for Peacock.
It allows you to collect user feedback from thousands of pages without the manual work.
You can join our EAP and we will notify you when the app is published (which will be very very soon).
Best regards, Adrian from B1NARY (we are the developers of Peacock).
