How do I build headers/footers into Confluence pages?
Josh Bowie
June 10, 2025
I have build a page in confluence that when exported as a pdf is comprised of several pages. I am trying to see how a header and or footer can be assigned to each of the pages. Any direction is much appreciated.
Ignacio Ampuero June 10, 2025
Hey!
I looked on the documentation, and found out you can add custom footers and headers for pdf exports.
Take a look on:
Advanced PDF export customizations | Confluence Cloud | Atlassian Support
and
Customize layout for PDF exports in Confluence Cloud | Confluence Cloud | Atlassian Support
It's not very WYSIWYG but it's supported tho
Hope it helps!
Josh Bowie
June 10, 2025
Thanks so @Ignacio Ampuero I will give this a try.
