Am I able to create a title with two text colors in the panel macro in Confluence? If so, how? Also, can I change the font? How?
You can do it with a modified panel:
image2017-1-24 14:0:45.png
Add some CSS to the Styles field of the Div macro
background: yellow; position: relative; left: -10px; top: -10px; padding-left: 10px; padding-top: 5px; padding-bottom: 5px; width: 110%;
To change the font, add the font designation to the CSS in the Styles field, e.g.:
font-family: Times;
So,
background: yellow; font-family: Times; position: relative; left: -10px; top: -10px; padding-left: 10px; padding-top: 5px; padding-bottom: 5px; width: 110%;
image2017-1-24 14:9:46.png
Thank you so much! Would this also allow me to paste a logo in the header? Like a banner logo?
L
Yes.
Hi Lena,
Adding a header image is used as an example in Atlassian's Basic Styling Tutorial. That should point you in the right direction.
But can that same method/CSS be used in the context of a panel macro? If so, how? Do I find the panel CSS and include it there? Thanks again.
