How do I highlight text with color in confluence?
Cobin Bluth
June 7, 2018
I have some documents in my Google Docs that I would like to transfer to Confluence.
My document makes heavy use of highlighting text in color to differentiate certain contextual elements in the document.
Nidhi Raj
August 5, 2024
12 votes
David Oekroes
December 8, 2021
I still don't see any options for highlighting text easily. What are your plans in this regard?
11 votes
Manon Soubies-Camy
Hello Cobin and welcome to Community!
There is an open feature request: Provide ability to easily highlight text with color in WYSIWYG editor, you can vote for it to show interest and watch it to be updated.
You can use macros as a workaround:
  • Info (blue)
  • Tip (green)
  • Warning (red)
  • Note (yellow)
  • Background Color (custom)
  • Panel (custom)
  • Status (single words)
You'll get this as a result:
Hope this helps,
- Manon
Laura Servidei November 5, 2018
how do you make the status box that big? Mine is only a few character wide, and after that it shows "..."
Like • Charles.Dupont likes this
Manon Soubies-Camy
Hello @Laura Servidei,
The status box is small and ends with "..." while in Edit mode, publish the page and it should be bigger :)
Like • Eric Miller likes this
DOH!
Thanks.
Like • Manon Soubies-Camy likes this
Vishal S
June 1, 2022
but still when i wanted to make my header in red color background i am not able to see red color in the background color list can someone help me on this,
Karan Shah August 16, 2022
There is no background colour option available. However, work around is use macro - status i.e., custom label.
Bilal
September 13, 2023
It's remarkable that there's no text highlight for an enterprise-grade software. Why are you charging customers when customer still has to "vote" for a very basic feature?
Like • 23 people like this
Johannes Gubo
November 5, 2023
@Bilal agree, it's completely stupid and counter productive. Atlassian keeps failing for over a decade to delivery some of the most basic features across their entire product lineup.
Like • 3 people like this
9 votes
Zoriana Bogutska_Kolekti-Adaptavist_
December 12, 2022 edited
Hi there,
Using Mosaic for Confluence it is easy to highlight text using a background macro.
Also, for background, add-on users can upload pictures to improve the Confluence page design.
This app is developed by my Adaptavist team, so if someone has any questions - I'm happy to help.
9 votes
Stephen George
March 22, 2022 edited
One workaround available is to insert a simple, 1-cell table (by typing /table) and choosing from one of the available palette colors for the background of the cell:
Result
5 votes
Scott Morris
October 19, 2019 edited
not really an answer. more of an add-on. i really want to highlight text inline from my page, not put it in its own box. i need to identify code to be changed vs. code that is good. maybe i'm just stuck in an old version of confluence?
Hitesh Jain March 23, 2022
If you figure this out please share it.
Dean Ramdhayan
June 7, 2023
This is the most basic function for documentation, how are you worth billions of dollars and not able to implement this
John Bartlett
March 20, 2023
Yellow highlighting is typically used to indicate 'work to do' in a document. I achieve this by commenting on the text, which highlights it in yellow and add a comment in 'to do'. Using comments for highlights in this way has the added benefit of providing you with a list of you highlighted test on a page. Here's an example:
kris.van.de.vijver
April 24, 2023
That's a perfect solution for me, thanks for this tip/workaround.
Alan Pham
May 5, 2023
Brilliant!
lorant_z
March 4, 2024
2024 and confluence still cannot highlight text background.... unbelievable....
Dave Hildebrandt
May 27, 2021
Use the span macro to set the style.
Andrew Rothman
August 10, 2021
Where do we get that?
Like • 6 people like this
Morgan Day
February 26, 2022
I can't find it either...
Like • Jon Andersen likes this
Adam Hechler
I don't see a "span" macro
Alex R_ April 14, 2023 edited
I have no idea what macro @Dave Hildebrandt was using, but I created my own:
## Macro title: Span
## Macro has a body: Y
## Body processing: Rendered
## Wraps content in a span tag with optional class name and styles for the tag. Do not include quotes in the class name or styles.
## @param Id:title=ID|type=string|option-showValueInPlaceholder=true
## @param Class:title=Class|type=string|desc=The class of the element
## @param Style:title=Style|type=string|desc=An inline ctyle definition
## @param Title:title=Title|type=string|desc=Text to display in a tool tip
<span
  #if ($paramId)
    id="$paramId"
  #end
  #if ($paramClass)
    class="$paramClass"
  #end
  #if ($paramStyle)
    style="$paramStyle"
  #end
  #if ($paramTitle)
    title="$paramTitle"
  #end
>$body</span>
Like • Mani likes this
jhonwills72
Banned
March 17, 2024
To highlight text with color in Confluence, you can use the Text Color plugin. It allows you to select and apply various colors to your text, enhancing readability and Gta 4 visual appeal. Simply install the plugin from the Confluence Marketplace and follow the instructions for highlighting text.
Achim Haag
"Gta 4" -> h....://cracksofshah.com/ obviously no serious content...
nicooletahehe
November 23, 2022
I used the 'Highlight' Macro:
or the 'Background color' Macro. This one highlights the whole row, though ^^'.
Adam Hechler
Where did you find a "highlight" macro? Did you purchase an add-on macro? Are you using Confluence Cloud?
Like • 4 people like this
Achim Haag
As always: what I expect as a Wiki default must be bought
SG
March 2, 2021
Looked promising, but is only available for server, which is no longer sold.
It's disappointing that text formatting options are so limited on Confluence.
Like • 10 people like this
Morgan Day
February 26, 2022
Ridiculously limited
Like • 5 people like this
