not sure if this is the right platform for my question, but let´s try:
We use the app "static snapshot". It takes snapshots from Jira filters on the page. This worked until december 2022.
Since then "com.atlassian.confluence.api.service.exceptions.PermissionException: Apps are not allowed to make requests using Application Links." is shown instead of the jira filters.
We use confluence cloud and jira server. Of course i set up the application links (QAUTH)
any ideas?
kr
Andy
In order to connect your confluence cloud with your jira instance you should go to:
However keep in mind that impersonation isn't working on cloud.
thx for the answer. Unfortunately, there is no "confluence cloud migration". And as i posted: it used to work in the configuration jira server and confluence cloud already, but stopped suddenly...
regards
Andy
The log files can be a source of truth then. Did you happen to check them?
Sorry for replying this late...
Which logfiles do you mean? i digged through all, but could not find any help.
