How do you get rid of the top blank 'dot' hierarchy point in a table of contents macro?
Ben Loughton May 18, 2016
Guys, i'm sure we are all aware of the 'blank' dot that appears in the hierarchy macro when displaying a table of contents?
This is driving multiple divisions at my company, crazy.  Any ideas?
Thanks.
Ben.
71 votes
Hal Schoolcraft November 28, 2016
I found that when I added the table of contents after I had created some content, the line containing the TOC macro retained the Heading style attribute that the previous first line had. Changing the style for the line containing the TOC macro back to Paragraph fixed the problem.
Sarah Underwood
October 12, 2018
You are a lifesaver, thank you for posting this!
Like # people like this
Mike Loux
OMG, that was so simple.  Feeling kind of dumb now.  You RAWK.
Rounak Agarwal
January 17, 2019
This was really helpful. Thanks
Jon Mulhern
January 29, 2019
Thanks Hal!
Jagan April 16, 2019
Thanks, it worked
Unni Flagtveit
June 17, 2019
Thanks Hal!
vangel
July 2, 2019
Thank you!
stephanie.rothfuchs
September 18, 2019
Awesome! Thank you! Such a simple fix
Kim Abbott September 20, 2019
Thank you!!!
Natechawin Suthison
October 11, 2019
Thanks a lot!!
Dominic Giger
October 11, 2019
Hal, you totally rock and just made my day! :)
Neal Madlani
October 31, 2019
That was driving me spare!
4 votes
Moshe Ben-Ezra
August 19, 2017
In my case this solved the problem:
My first section looked
[table of contents]
my first header [H1]
Aparently, the newline after [table of contents] was also H1 and it caused the problem. so I deleted it:
[table of contents]my first header
and then entered a (soft?) new line SHIFT-RETURN to seperate them
[table of contents]
and the empty dot disappeared.
Vincent Cirilo
April 15, 2019
Thank you this solved the issue. Although I think it can be simplified.
You need to remove the line between the Table of contents and the first header.
Simple explanation:
Setup page like this: [table of contents]first header [H1]
  • Between the [table of contents] and first header click SHIFT-RETURN
  • This will move the first header down without a space between the two
3 votes
Samantha Joksas
January 16, 2018
I found the above solution worked, changing the heading to paragraph.
When i edit my document, and put my cursor at the end of my table (so right beside my table) it was recognizing the table as being in header format, so i changed that format to paragraph and saved and it removed the dot.
Rodney Hughes
May 18, 2016
I haven't seen that myself!
can you provide a picture of it?
Sorry to ask given it seems many are experiencing this: Are you sure you don't have an extra line before the heading line that is also marked as that heading style - it might be an empty line but still holding the heading style so it finds the line and includes it in the list albeit the line has no text on it
