How to Insert a Jira Timeline into a Confluence Page
Kegan Cassidy
Hello
I am trying to insert a jira timeline into a confluence page. When the popup appears to select the timeline (screenshot below) it only shows one project to select as seen in the screen shot below. It only gives me the Odoo 16 project to select and not the TaskFlow project which is the one i want. Can someone tell me what i am doing wrong here? Whats also really confusing is that the Odoo project is on a different domain alltogether ...bridgecorp-sa.atlassian.....
Bibek Behera
@Kegan Cassidy ,
Welcome to the community. Two things that come to my mind.
1> Do you have access to the same project in jira?
2> Is the project you are looking for is a next-gen project?
If you're using a next-gen Jira Cloud project, then only the Jira timeline macro allows you to add your project's timeline to a Confluence Cloud page.
-Bibek
Kegan Cassidy
Thanks for the reply Bibek. Yes, i have access to the same project in Jira. Not using next-gen/jira cloud. I have a standard jira licence
Like • Bibek Behera likes this
Bibek Behera
Try this
  1. Go to your next-gen Jira Software project and view the Roadmap.
  2. Copy the URL from your browser.
  3. Paste that URL directly into your Confluence page.
Kegan Cassidy
It worked, thanks a million :)
