How to add a Multi Selection list using Confluence Templates
Craig_Harley
Hi all,
i'm creating a template in Confluence and wanted to know if there is any way to create a list where someone could select 1 to many items that is input following selection as a comma separated list.
Taking this a step further, the items in the list should be url links to other Confluence pages
Laura Campbell_Seibert
I think you will need an app for that, and I'm not sure the drop down list macros will be able to convert the choices into a comma separate list. Is there any way to collect the information you need through a Jira issue? Multi-select fields would be easier to set up with Jira, but of course that depends on your full use case.
Kristian Klima
Hi @Craig_Harley
Would the Action item macro work for you?
Craig_Harley
thanks for the response, but it does need to be in the format of a comma separated list
URL1, URL3, URL6 ....
Kristian Klima
The closest thing I can think of would be placing the individual renditions into a table
or can try searching the Marketplace to see if there's an app for this usecase.
Craig_Harley
thanks Kristian, think I may need to find an app
