we want to add the Jira burndown charts for already closed sprints to Confluence. For some reason Confluence lets us only import the burndown chart for our current sprint.
We select: Insert more content-other macros-sprint burndown gadget
Then we select our Jira board and after that we are only able to select our current sprint instead of older ones.
Is there a way to fix this?
Thank you very much.
Is there anyone with an answer to this problem? I'd like to know too.
Shoud be a standard feature for rapporting purposes. you like to show the current and/or new sprint you are working on. But also the closed sprint, what you completed, what you didn't complete, etc.
You can use the Table Filter and Charts app to build a burndown chart in Confluence. The app provides a flexible configuration so you can select any sprint. You can find the instructions on the documentation site.
Hi @Markus.
External gadgets should solve you issue - https://confluence.atlassian.com/doc/registering-external-gadgets-204050482.html
The gadget is already registered. It will not allow you to select a closed sprint.
