How to add an auto-numbering column to a database
Avi Valentine
September 8, 2025
I have an existing database and want to add a column. Each new entry should create a sequential number (ID).
Tomislav Tobijas
Hi @Avi Valentine ,
As Trisha mentioned, databases currently do not support this feature.
There's a suggestion related to your requirement which you can check (and drop a vote) here: CONFCLOUD-78746: Confluence database improvements on the fields section and view
Tobi
Trisha Griffis
What Isn’t Possible Natively
If you’re using Confluence’s newer database feature (structured content DBs), you cannot auto-generate a sequential ID within the table—no built-in support yet.
And another query specifically for Confluence Database auto-numbering confirms no current support.
There are Third-Party Tools to Make It Happen
If native functionality doesn’t fit your use case (for example, in databases or needing formatted IDs like “001”, “002”), there are several good options:
A. Advanced Tables for Confluence (Table Plus Macro)
  • Provides auto-number rows and auto-total numeric columns.
  • You can set these up using {table-plus} syntax with parameters like autoNumber=true.
B. Table Filter and Charts + Table Transformer
  • Wrap your table with the Table Transformer macro.
  • Use an SQL-like query:
SELECT *, ROWNUM() AS "Sys Req id"
FROM T1
  • You can also format the ID with leading zeros using padding functions like padStart(3, "0"). Example: “001”, “002”, etc
Jer-nee Consulting is a Solutions partner and we are happy to quote the add-ons for you and pass along a discount. If you are interested in saving on the solution feel free to book a call with us here.
