I would like the ability to add capacity for each team member and then see the delta between the actual hours and capacity at the end of each sprint. Is this possible?
If you are on Jira Premium, you will have the capacity planning feature along with roadmaps. Not sure if Jira standard version has capacity planning feature. Another alternative would be to use a mktplace app. If you are fine to try out the same, you can have a look at the one we have developed for the same use case.
The app allows to store the capacity for individual users and save as templates. which can be mapped to a project / fix version to track the allocation and remaining time per user. Do try it out.
Disclaimer : I am part of the team which developed this app
