How to automatically fill in variables on custom templates?
Steven Garbarino
I know how to make a variable on a custom template, in which the user inputs the info for each variable before creating the document. But how do I get variables to automatically fill in like the pre-made Confluence templates? Variables like current date and document owner.
Thanks for the help!
Steven
Kate Hanna
I also would like this - I've just given up using variables on my custom templates because the experience for the user of the template is so bad.
Jan
We are using Page information which is free and works perfectly for us. You can add info like create date, create user, modify user etc. automatically by adding this macro to a page or even templates.
Milo Test
November 9, 2016
That's only available for Server and the OP is using Cloud.
Kate Hanna
But thanks anyway Jan, we're on Server and I'd been following this thread in the hopes of help for us. smile
Rob Woodgate
October 30, 2016
By default variables can't be auto-filled with values like current date or username.
I don't know if there is a 3rd party plugin that does exactly what you need, but you can find a list of template plugins here.
